effects of using wrong plugs
Don 79 TA
Still Fat....
you can also run a BPRXES plug
the p is a projected tip,
X is the heat range,
i usually run a BPR7ES plug
never a fouling issue, and helps it burn good
i also run a little thicker on the oil too and high compression
BPR7ES-11 is a solid tip plug
I have to remember to order some on my next summit order :)
