Ebox seized on the bracket
I just bought a Superjet that was used in salt water ,I removed the 2 bolts that old the ebox and even with a very good loose nut ,the box is not moving at all,
any tricks
thank you
Personally I always remove the bolts that hold the brackets from the tray. Remember also that there is a screw under each bracket which must be removed to split the E-box.
thank you , One hour after I post it, I just thought about it, the same thing happen to me on a VXR pro 1995 , I was just suprise that I have the same problem occurred on a Superjet 2020
