Dual cooling routing?
I saw someone made a dual cooling diogram on here some time ago but i cant find it, can someone help me out? does the factory pipe come with enough hoses to do dual cooling or will i need to get more?
this is where im at now, the chamber is not hooked up yet because there are nipples underneath that lines goes to, the manual only shows how to do single cooling. want to make sure i get it done right.
http://i17.photobucket.com/albums/b88/nickt916/DSC02688.jpg
nikad58
1974 YZ 701
I could be wrong but more like mistakin..
the 1st/3rd picture is the closest to being right.. but.. you should have one more outlet on your head and going overboard, reason ? you have twice the water coming in you need a way to get more out to cool it from more cold water coming in..
the 2nd picture is just seperate cooling and does nothing to help the engine be cooler over single cooling other than two lines from the engine going overboard.. you cando the same thing with a added outlet on the head.. it might keep the pipe cooler is all..
