Blaster dual carb help
Is there anyone that can give me some advice.....I put my buddys motor together and its a 62t bottom end 61x top end 760s with r&d dual Carb mainfold on it with mikuni 38s....there are a total of 8 outlets....2 on the manifold and 6 on the carbs....does anyone know how to run the fuel lines or have a picture for me?......please help!
Bobert540
Rockford,MI
The two on the manifold, you will want to take a line from each one to the pulse line on the carb. Make sure those hoses are the same length.
On the carbs you have a fuel in and out outlets. Tee the two returns to the return line in the tank. then you will need to run the fuel pickup line to the inlet side of the carbs.
