driveline couplers- blaster
anyone ever seen the coupler not to be "true"?or the threaded parts to be off?
i have a friend who is on his 5th set of shafts in his 95 blaster what a pita
i have shimmed it perfectly but could the be off?
thanks
jason
has he change the carrier bearing and carrier, they wear out also giving the short shaft to much play
I also had an old square that was so beat up the same thing would happen, I think the hull became weak and had to much flex, it was in very bad shape, switching hulls sold that problem
thanks tom but the bearing /carrier are fine
he does have some wear on the bottom of the hull in front of the intake grate
i have told him of everything i could think of to help correct the problem
firewall flexing
couplers being off
free reving motor while in the air .. only to slam it with water upon landing
shimming as long as the couplers are true is spot on!
he get about 1 years use per sub/drive shaft
the primary use is gulf wave jumping.
WaveDemon
Not Dead - Notable Member
Hell, Florida
ewok was going through shafts like crazy on his blaster. I think he ended up fixing it but don't remember what it was. you could send him a pm.
