300/440/550 Drilling for Duel Cooling
Pwgsx
Go big or go home
DFW-Texas
You can’t really see it, but the fitting is really loose because the wall is so thin there are not many threads for it to hold. I would feel better if it were welded somehow. Probably have to grind it down too on the inside, because I don’t think you want it protruding into the pump. How do you guys get this to work?? The 550 pump does not have a thick piece of metal where it could be tapped OR did I just jack this one up?? Its on a 86 550 btw. Thanks
Dustin Mustangs
uʍop ǝpıs dn
Holland, MI
:starwars: :laugh2:
Those fittings are available in 1/4" npt as well so you could still rethread it for one of those. However, I think I'd just use some of this and call it a day:
Pwgsx
Go big or go home
DFW-Texas
i am using the stock bildge line so thats why its on the same side, but other than that, i might try the jb weld.
