does pro-tec pipe make good power on a 650sn?
If you are talking about the old skool S/S chamber version with the stinger pointing down...its a great little pipe for the 650. Doesn't have as hard of a hit down low but then again, we are dealing with a 650.
If you find one with the exhaust manifold (instead of using the OEM manifold) for cheap, go for it. I wouldn't pay more than $130 for it.
FreestyleFreak
Region 7 AM Freestyle
hmm
So it wouldnt really help the bottom end any?
How much punch do you think a 650 would have with a b-pipe and milled head and 13/16 skat?Do you think it would have a pretty good bottom end if tuned right?
That old pro-tec pipe for the 650 is okay but the bottom hit isn't the same if you had a 650 b-pipe. Bottom, mid and top will be improved on the pro-tec over stock.
If money isn't the issue, buy the 701 limited b-pipe for your 650. This way when you wake up and drop a 701 in your SN you are ready. Besides, b-pipes hold their value better than homes and I plan to stock up this winter.
Mouthfulloflake
ISJWTA member #2
NW Arkansas
the black proteck pipe on my sons boat makes great power.
pipe and ex manifold, protec head, makes 180 psi, 650 engine, its very strong for a 650
advanced timing and MSD enhancer and bored nozzle, and the bottom end hit is great ( for a 650)
