SXIPro
JM781 Big Bore
- Here on the 'X' mostly
I use 1211 around the studs to try and keep water out of the thread area but never seen it come out like that. If it did come out Maybe spray a corrosion prevented down in there. You could retorque the girdle nuts too just to make sure cyl isnt loose. I doubt its leaking there either.
Sent from my SM-N950U using Tapatalk
But I trust YOU more than ADA since you built the motor.Ada says 23lbs.![]()
