dirty stator and flywheel...pics added...pressure test complete
Haiti
pulled the flywheel cover and flywheel today...man its ugly in there.
looks like there was grease and some oil flying around. besides the bendix, didn't think anything in there gets greased. is this normal?? i'll snap some pics and post them up later. just making sure before i start chasing a leak that might not be there:dunno:
PICS:
Haiti
i'll post some pics tomorrow so u guys can judge better what it looks like...
#.0 i had the gas tank out so i already went ahead and removed the old flywheel to make place for the one your sending me!
Haiti
when removing the cover there was no gas smell (if there was, it was not strong enough for me to notice it). its been open over night and has had time to air out...but the is no strong gas smell now either
take a look at the pics, all that gunk does not seem normal to me
#ZERO
Beach Bum
Florida - U.S.A.
That pretty bad with the oil pooling up on the bottom and getting thrown around.
I'd replace the crank seals while the engine is already out IMO.
Just flip the engine over with the spark plugs out, remove all the bolts, bed plates, bottom cover and turn the crank so the pistons are even, that way you won't have to disassemble the top end.
Haiti
can someone run through the proper procedure for a leakdown test...should be simple enough so i'll do the test before openening up to getto the seals...
also what's the best way/product to clean the stator/flywheel area?
2lick
Brap!!!
Limerick, PA
For pressure test check the tech FAQ... if you dont find it let us know
Haiti
thanks 2slick found it, read it, aswell as other stuff i could find using the search...
gonna have to wait for my new head gasket before doing the test though...
#.0 can u elaborate a little on why the pistons should be even, this might be a stupid question but i'm just trying to understand why u pointed that out specifically.
Haiti
ah hah!! makes perfect sense...
have three new seals on hand, gonna do the pressure test and replace the seals if needed...will keep u all posted
SUPERTUNE
Race Gas Rules
Clearwater Fl.
I'd say unless somebody soaked that bendix in oil before installing it and then slung the oil out and all over, the crankshaft seal is leaking. Use only OEM seals from Yamaha.
Haiti
what kind of symptoms would a failing crank seal give?? i'm curious...
keep in mind i did not remove the flywheel because i had a problem (although i do) it was removed simply to be replaced with a lighter one...
chrisdoc0608
insulting
rocky mount, nc
ummm the worst symptom of crank seal failure would be leaning out your motor and frying it, or it free revs and crashes... I dont know which would be worse
