System One
Product Description
SYSTEM ONE X3 Polish works great in the body shop! Imagine one product that takes you from color sanding to a perfect shine. Use a wool pad to remove color sanding scratches and a foam pad to remove scratches left by the wool pad. No longer worry about cross-contamination between multiple polishes, since you are using just one polish. Also, unlike other compounds, there is no harsh odor or staining with SYSTEM ONE X3 Polish. The product is water-based, so cleanup is a snap.
For detailers, enjoy high-quality finishes with one pad. For tough oxidation and scratches, start with a wool pad and follow-up with a foam pad. Any polish splattered on the windows or trim cleans up easy with soap and water. Best of all, no more swirl marks!
For the do-it-yourselfer, polishing has never been easier or safer! You can polish without the worry of burning your paint or wearing down edges. This product is perfectly safe for all finishes and you don't need to be an expert to produce a showroom shine.
SYSTEM ONE X3 Polish Features and Benefits:
* One product replaces three polishing compounds
* White residues will flake off when dry, as the amalgam has an anti-static base
* Does not stick to paintwork like other products
* No swirl marks after polishing
* Environmentally-friendly, lowest solvent content
* Non-toxic, water-based
* Will not separate if left to stand
* No solvent aroma or fumes
* Highest surface coverage saves money
* Safe to use; will not burn edges
* NO FILLERS; scratches will not return, because they are not being covered up
* Works on all paints; fresh paint, cured paint, factory paint, even ceramic clears!
* OK to polish on hot surfaces, even in direct sunlight!
http://polishandwax.com/shop/products/SYSTEM-ONE-Polish-Quart.html
