deka ext 12 for TL
skinnyman
YOU CANT RENT MY SKI
Dallas/ToyBox
Im looking to shave all the wieght I can
specs on ext 12
capacity at 10 hr 10 ah
cca @ 0deg 180
wieght 9 lb
curent current 1.2 a
Im running a stk stroke lamey 85mm
MSD digital TL
1 pump running while I ride and 2nd pump runs evey once in a while
The ? is can I get 4 hrs of ride time out of this bat w/out charging?
Has anyone run the ext 9 or the ext 12with TL how much ride time can you get ??
Aircraftsalz
Thrust built Dasa Power
Off site
Larry
I was running a very small 4.5lb battery from advance with my Superfreak hull. 860cc XS, High compression at 225PSI, TL, etc. Battery ran 4-5 tanks without any problems, which thats all you want with that flatwater ski.
Larry
On average, how many starts did you do in those 4-5 tanks?
Foximus
CFL Cheapass.
Oviedo, Fl
I use a deka ETX15 and feel its a good compromise. 230 tested cranking amps, yet pretty light, about 2/3rd the size of a normal batt. I believe it weighs only 11 lbs.
Aircraftsalz
Off site
That setup was in my Superfreak hull which is the ski I sold Larry. I would say at least 7-10 starts each tank. I would ride the ski all day long & not think about the battery. But I was also running a motor that always started right up, XS brap!!!
I run this same battery on all my Ski's!!!!!
Not running the bilge pump.
lots of starts, never an issue with that setup! that ski was great, it even towed in backwards!!!
Waternut
Customizing addict
Macon, GA
What kind of battery is it (brand/model)? If you're getting that kind of performance out of it, I should be plenty fine with it. I'd be happy with 7-10 starts a tank and 2 tanks of fuel. 8 gallons of gas is more than I'd be able to ride in a single day anyway.
