ok, defoaming is in progress
both of the tray walls are out and all of the foam reachable is out.
the question is, how do i defoam underneith the front of the tray?
do i have to cut the bottom out too?
cheers
Dan
im thinking about cutting the whole bottom of the tray out so i can also seal all of the hull inserts and seal the rear bondline
any thoughts?
thanks for the help
Dan
any thoughts?
thanks for the help
Dan
Are you refoaming? Any weight advantages with this process? I'm thinking of doing the same on my SXR to remove the wet foa and excessive glue and other materials.
