Lucas additives for the win.
Seriously, a working oil metering pump is a bit dynamic - at idle and low RPM - it could be mixing oil at 100:1. At full throttle; it could be pushing more like 24:1.
What I do to fix the whole problem is carefully remove the precision oil pump as to not disturb it and make a royal mess of things inside my hull. I then carefully take the pump and, while standing, lower it to the ground between my feet with both hands cupping it so that it does not accidentally fall to the ground and get all dirty. I then lift upwards with all my might (Spinach helps) while a friend bird-watches the pump as it flys as high as I can throw it (Limited by gravity and physics of course). Take a measuring tape and measure how far it gets thrown and write that down in my jetski notebook for later use.
Then I take my trusty $2 ratio-rite from Walmart and add 40:1 mix of Klotz R50 to my gas cans.
Works every time.
