SJBrit
Extraordinary Alien
- Bradenton, FL
I just about want to throw up right now. Flywheel bolt came loose, punched through the stator cover. When I pulled it apart this is what I see on the front of my crankshaft. Any hope at all?
You'll need more than lapping to remove that gouge mark.
I would use a flat file like Check said on the snout high spots with a new flywheel, woodruff key and bolt too for a quick fix.
Also your front seal is leaking and SBT cranks are 200 bucks.
Yeah strokers are more expensive and SBT won't have those in stock.dont see using an SBT Crank with and XScream 865 motor.
