Dasa Waterline size
Hi, I have not found writings about.
I am going to install a Dasa 1100 engine with PFP and pump MAXX 148 on my superjet hull.
Currently I place a double waterline 3/8, but I noticed that PfP manifold has a graft wider.
Then I have to replace my waterline mounting of larger pipes, or double 3/8 may be enough to cool this engine?
Thanks
the bottom manifold fitting for the pfp is 1/4 pipe, 1/2 in barb. You can buy the same fitting but 3/8 barb. I have found that if you heat the clear blue line a little bit, it will stretch over the 1/2 barb. I also found that with the rrp pipe they send silicone water line that fits 3/8 and also fits over 1/2 also. What temp water are you riding in?
  • Like
Reactions: DAG
I mean about the temperature of incoming water.
I do not know the temperature of the engine as it is new and I have yet to mount it.
i ran all last season in water temp from 50 Fahrenheit to 90, running a single cooling line to the motor and to lines coming off the head. I never had an issue. Thats with a dasa 10mil 1000
