Ran a couple of tanks through it sunday and jetted the carbs , a set of novi 44s . Runs strong especially in the midrange which is what I want . Will put a set of novi 48s on it this saturday to see what the difference is . Cylinder has not even been ported yet and no case matching either . Wanted to see what it ran like before and after . The transfers match the sleeves worse than a 61x yamaha so I know there are gains to be had there . Also need to match the exhaust manifold and open up the headpipe . Only limitation there is the factory pipe manifold is thin due to waterjacket an if its bored to big there could be issues with the gasket sealing . This cylinder bolted on without any case boring which was cool .
