DASA 900 PV, 148mm pump, Factory Pipe, MSD TL
Mich
I have a DASA 900 10mm stroker with Power Valves that is on the original bore with 195 and 198 psi. Motor has seen only a couple of tanks of gas per year for the last few years.
Factory pipe, exhaust manifold (still on motor) clearanced to fit the power valves with Jet Works flow valve. All screws work. It appears to have had a repair that does not leak (I was not aware until I pulled it from the ski).
MSD TL ignition with fly wheel (still on engine).
148 mm pump total pump assembly with trim.
Full Spec 49 carbs
Would like to sell as a package $5750 Motor Short block $3000, pipe $750, carbs $750, pump $850, TL ignition $750.
Darrell 734 386 6657 Michigan
just an fyi.
The pipe was not repaired it was opened up to clear the old style PV's. This was common to do. The way this one was done in my opinion was correct way and is the way I did all mine. Machine out the outer jacket and then weld between the inner and outer layer so that the water jacket is sealed. Some people used to just grind the outer layer to just clear the PV's but left a very tight fit and it was very thin.
There were a few spacers made that mounted on the cylinder that pushed the whole pipe out. This allowed forno machining or grinding on the pipe. I may even have a new one laying around.
GLWS
Full Spec 49 carbs
Has the pump been sold? Thank
