New Crank works 4 mill stroker crank Kawasaki
Octane_114
LeT tHe gOOd tImEs RoLL
Charleston S.C.
It is a new crank, it was a spare that did not get used.
1000.00 bucks
Octane_114
Charleston S.C.
Do you have to do anything to the cylinders or need a thick base gasket or anything to run this?
You have to set the engine up properly. Cases need trenching along with some porting. I had shims/spacers cut vs using thicker gaskets. It’s how you want your engine built. You can’t drop this crank in a set of stock 800 cases and go. It won’t make a full revolution.
