Couple Questions
Hey what kinda carbs are you guys running? I recently purchased a rd intake and v force 3 reeds and a list of my other mods are wet pipe,timing advance, jsu girdled head, dual cooling, 80 mm nozzle, 14/22 solas dynafly, im not sure what size either 46mm or 48mm and either novi's or mikuni's. Im tempted to go with the mikuni since the price is so much less. But are the novi's a noticable difference and will my setup require the big bad novi's any thoughts? Also what size domes are you guys running to achieve 180 psi? Thanks!!
Idaho
Not sure about the carbs. I have almost the identical setup as you and still am running the stockers. The domes you will have to experiment a little bit with. I was running 28cc ADA domes to get 175psi. Your engine wear, elevation, and or porting will have an effect on this
