Couple bodywork questions
Broward
IMG_0097.JPG PIMG_0100.JPG IMG_0099.JPG IMG_0096.JPG IMG_0095.JPG i have a couple questions about the body work on my superjet:
1. How do i go about repairing this wierd thing going on where the hood seal goes?
2. I have some wierd like cracks in my paint that are not deep at all they almost feel like smooth when i touch them, what are these? I have a ton running along the face of my pole from top to bottom and a couple next to the tray.
3. What do you do to remove the sun fading on the nose area?
4. Last question, is the bottom of my hull in really bad condition?
Vumad
Super Hero, with a cape!
St. Pete, FL
1) That weird thing is a crack. Drill the end, reinforce.
2) Stress cracks in the gel coat
3) buffing
4) No, except try not to put anymore gouges in it like the one on the right. Looks like someone dragged it over a broken bunk or something.
Broward
3) buffing
What exactly do you mean by "reinforce"? Do i just get some glass and resin and lay it over that spot? Ive never messed with fiberglass before
Vumad
St. Pete, FL
So a stress crack is a non-structural crack in the finish. The pole has what looks like cracks but they are only in the gel coat. They are not affecting the structure of the pole, just the appearance. They can be a sign of weakness underneath and may reappear even after painting, but your pole or hull probably wont crack or break under normal conditions.
The 4th picture in your original post appears to be a crack. It looks like it may be complete through the hull. How it happened I can not say. The crack will continue to travel down it's path as the ski is weaker now than before it cracked.
Reinforcing is applying new material to increase the strength of the area. Generally you want to reinforce prior to failure, so it's probably more accurate to use the word repair than reinforce, but you may want to consider reinforcing undamaged areas if you expect to continue to abuse your machine.
To fix that crack, assuming that it is as deep as it appears, you will need some epoxy and glass. Drilling a hole in the end of the crack is believed to help prevent the crack from continuing it's path after repair. You will want to make your repair from inside the hull as an outside repair would alter your hood seal in a negative way.
You may need to remove your motor, especially since you are not experienced with sanding or laying up the glass. Sand and prep the inside of the hull. This includes sanding with 80 grit to remove debris and rough the surface to bare glass, then clean with acetone (lacquer thinner first if ever working on an area that had been waxed).
Overlap refers to the amount of material you need past the repair. So if you have a 1" hole but use a piece of 3" diameter cloth to fix it, you have 1" of overlap on both sides and 1" of repair (1+1+1).
I am not an expert on exactly which weaves are the best for which jobs and how much overlap is required. Personally I like 1208 glass with 3:1 epoxy resin. I'd probably do 2 layers of 1208 at 1" and 2" of overlap, maybe a 3rd layer of 1208 or 10oz at 3" overlap. If you are going to reinforce after the repair, do 2 layers for the repair at the same time you reinforce, making the reinforcement the 3rd layer of your repair but 1st layer over everything else.
Again, i'm not an expert on exactly what is the best balance of weight and appearance. I tend to try to over build so it doesn't break again.
Finish up by using a small amount of filler on the outside and some touchup paint. You could consider a thin layer of glass on the outside but I wouldn't put much more than like 4oz where your seal goes.
Broward
Wow i didnt expect such a thorough explanation, lol, thank you so much for this... time to order some glass and epoxy!
Vumad
St. Pete, FL
Safety
Nitrile or other gloves
drywall sanding masks
Prep
80 grit paper for prep, buy the better of the 2 kinds of paper at most hardware stores
acetone for prep, (lacquer thinner too if you need to remove wax)
(optional) packing tape and drop plastic to mask off areas not being worked on
Layup
1" and/or 2" chip brush to put down epoxy
disposable mixing cups (You can save yogurt and other food cups to pinch a few pennies)
3:1 2 part epoxy
glass you want to use
Fiberglass roller, optional for a small repair but still recommended. 1.5" is fine for the repair
Feather/blend
talc to thicken the epoxy
(optional) glazing putty for pin holes
higher grit papers to the number you want to finish the job too
Although I am unsure of what the 1200 series glass is, I have used some very good glass called 0/90 biaxial stitch. It has held up solidly, something for additional consideration to what Vumad mentioned.
