Could this cause a lean condition? **pics inside**
Danny Kay
SJ + M3 = awesomeness :)
Atlanta
Check these out, one carb (the first one pictured) is running lean after i installed bpipe, head, and MSD. Im thinking the extra demand for fuel might have cause a allready present problem to immediatly worsen. the dirty carb is too lean to even ride. Could this gunk cause it? And what can i do to correct the problem? Any ideas? The second carb pictured is the carb running right.
Check popoff pressures of both carbs, and make sure they are tuned equally. Clean the fuel lines.
Danny Kay
Atlanta
is a popoff guage somthing i can pick up locally? Im a carb newbie. thanks for the suggestions.
The front carb (dirty one) seemed to lean out more as i richened it up? Like the first carb (rear) was stealing all its fuel, is that possible? I was making equal adjustments to both carbs, at the same time.
tor*p*do
Squarenose FTW
NW NC
always make the pto (rear) carb a little richer.
that side of the motor atkes more lugging
that is why when a motor leans out and fails it is almost always the pto cylinder that goes first
Danny Kay
Atlanta
its my front carb that is leaning out really bad. Its like there is only enough fuel being fed to the carbs to fed one of them. No clue what to do, guess ill give i try what matt said.
ANT
Just ride
looks like you got water in it. make sure your return isn't clogged in the cover, it's only a little tiny pinhole. put new fitlers in it, they catch everything and the little stuff can clog them up real easy.
