- Sacramento Delta
Last weekend at the end of the day, I noticed that the stock 61x 701cc in the FX-1 wasn't running as well as it should.
Today it was noticeably worse. At our "private beach," I pulled the hood and looked to see if the hose clamp connecting the muffler to the hose going to the water box had come loose, because I had that happen before and the exhaust gasses leaking into the engine compartment starved the carb from oxygen. It wasn't loose. So I put the hood back on and it was better so I road some more but had to limp back to the boat launch.
I was taking the carb off so I could take it apart to check the internal filter and, for the first time, I noticed this little hose was off.
Sure enough, although it is little, it really spews exhaust out. So, could that be it?
The original oem constant tension clamp is way too loose to do anything, but I think I have some constant tension clamps that size so I think I will forget about the carb for tonight and ride tomorrow and see how it goes.
Is water supposed to come out of the head into that little hose and then go to the muffler? If so no water was coming out when I just started it. But then again the ski is not in the water...
