300/440/550 Correct way to put driveshaft coupler on conversion ski
550headache
tobacco grower
tobacco valley
Got my 440 coupler off easily and threaded it on the x2 driveshaft required for the 750 pump conversion. Do i just put this on as hand tight as i can? Blue lock tite? I could put a pipe wrench on the shaft and tighten the coupler but dont want to marr up a brand shiny new X2 driveshaft. What do you guys do? I imagine it will only tighten itself on when it running with a load, correct?
Sent from my iPad using Tapatalk
dfw
The coupler needs about 60 pounds of torque. Theres enough torsional oscillation to cause a loose coupler or impeller to spin off. You can hold the shaft with soft blocks in a vise or use an old impeller.
