Hi I've read in this forum that the correct clearance between the 2 couplers should be 2-3 mm. But I just had my midshft and housing rebuilt by a shop here and then took it home to install, after finished, the clearance is now at only 1-2mm. Is this ok? I'm kinda lazy and really dont want to remove it again. Ahhhh!!! if it's ok I'll use it as is.
Thanks a lot guys
Thanks a lot guys
