dirkdiggler
- WI
How far off can a Walmart $25 compression tester be???
I bought a jet ski couple weeks ago and the guy that I bought it off of had a decent(I think) compression tester. Both cylinders ended up at 150 psi on his compression tester.
Today, I checked the compression in the same ski with my compression tester and it came out at 115 psi. Is this possible??
On my Walamar tester
1991 Superjet 650 = 125 psi in both cylinders
1994 FX-1 = 120 psi in both cylinders
1989 650sx = 115 psi in both cylinders
should I just add 35 psi to what my tester shows and assume that is the correct psi???
What are the original compressions when new for each of my ski's???
