Super Jet Compression questiion
I fresh rebuild all engine, brand new piston and oversize , new ada head. After 3 rides I stop cuz I heard a little intermitent sizzling noise like a pressure in the carbs ( dont know how to discribe the little noise i heard ) I put the head out .. cyl out, there was lot of wear near exhaust port, but piston was a1. I rebuild up with gasket and stock head, I also pass the stones to refresh the cyl ... start up .. same noise, 5 or 10 lbs more compression on the same cylinder. same problem. It also crank slower when the gauge is on the low comp cyl.
compression pressure is based on ring seal and head gasket seal, period. if one cyl is lower, its the ring seal, if everything is the exact same per side. squirt a little oil in the low cyl and do the test. if its up, its ring seal and i already know it is.
