This is a spare kit I put together. Includes everything you need to bolt on and go aside from an oil block off plate. All parts are OEM and the flywheel has the third lump removed already. CDI is brand new. I installed the kit on my ski for test purposes only. Fires up and runs as it should. It’s set up and programmed to run 2 curves by plugging or unplugging the two wires coming from the temp sensor grommet. Currently has the 2 stock curves on it, wax racing and a milder 25 degree curve but I will gladly program any curve you wish before shipping.
$700 plus shipping/fees
