Freestyle Cold weather riding prep
this is by far the best suit I have ever worn... worth every bit of 300$
XCEL Infiniti 3/2 X-Zip Wetsuit 2011: The easiest full wetsuit you’ll ever own, the XCEL Infiniti 3/2 X-Zip Wetsuit offers unattached zipper flaps and extra-wide crossover neck entry. The X-Zip System features a water-resistant Interlock zipper and SmoothSkin elastic shoulder hems along zipper flap edges for a contoured, flexible seal. Plus with ThermoCarbon inner chest and lower body, the Infiniti 3/2 X-Zip is prepared to keep you warm and in the water longer. Material
100% UltraStretch neoprene is XCEL’s stretchiest, softest and lightest neoprene.
ThermoCarbon inner lining is critical in heat-retention, made of bamboo charcoal infused fibers and recycled fibers.
Special Features
Upper body Fusion Seam Technology: Pressure Bonded taped seams in the lower body. All seams are contoured to maximize flexibility and comfort.
X-Zip System is front entry with open (unattached) zipper flaps for easy entry/exit.
Crossover Neck Entry is an overlapping inner front and back neck panel for durable, easy on/off solution.
Geometric Ankle Seals
DuraFlex Knees are pre-bent.
Specs
  • Wetsuit Thickness: 3/2 mm
  • Material: Neoprene
  • Seam Sealing: Glued and Blindstitched Seams
IMHO - Surfing wetsuits are 1000000x better than any jet ski wetsuit.
I rode yesterday 47 degree air, 40ish water. 3/2 wetsuit with an extra top, helmet boots and gloves. Pretty good but my motor would not warm up so I quit and installed limiters in the pissers today. Water here will be in ice form shortly but its still good out there.IMG950045.jpg
Yep, I bought the 5/4 its worth every penny. Match that with the matching 7mm booties and im ready for 35F water temps.. except when ya get hit hard in the face with cold water it can hurt and knock ya unconcious.
To OP, this suit http://us.shop.xcelwetsuits.com/p/surf/mens/wetsuits/drylock-power-seam-43?style=MB43DRP2
with the matching interlock booties http://us.shop.xcelwetsuits.com/p/surf/accessories/boots/drylock-round-toe-7mm?style=ABV79811
your feet will never be a issue. i love my set up and ive tested it in 38 F water temp i think 40 F air. as for hands, i still havent figured out something i can be happy with. my crappy gloves only work good as a windbreaker. maybe ill do the hot hands mod this spring.
EDIT: Ah crap I didnt see the first page and ur in florida. Scale my recommendeations down then
