Coffman Sizzler setup and tuning
CRJ
Hibernating
Toronto
i think on the 44 i had i ran 135m 120p. if you can get a 701 top end, the porting is VERY different.
This is just my backup ski it will stay a 650 for people that are new to all this stuff. Just need her to have a little more pep than totally stock lol
King Kang
Never enough tray time...
Cary, NC
Can anyone point me to jetting recommendations for this pipe.6m6 35cc Ada head. 9 15 hooker
I posted the instructions from Coffman earlier in this thread and they specify the jetting for a 650. I changed the needle as they recommended and it runs perfect. I have a 9/15 hooker too, but the head is stock.
mattT44
classy
ATL
I'm trying to find out on my sizzler if I need open flow ports on the gasket or keep it whole. I can't find any info on that anywhere.
the Coffman's has a couple of great sweet spots with 701-760 engines, its secret lays in the water restriction and will differ with water routing dual or single... also head pipes differ with 2 or 3 pissers.
From my experience >> The pipe itself should not be dried out so much that pipes actually sizzles , a good starting point for dual cooling is to restrict head approx. 4 mm and the stinger side approx. 3 mm. ( if you don't have a flow control valve ).
Our jetting was always run with a 1.5 N/S which seemed to work better than the Coffman's suggested 2.0 N/S, but we also had a higher pilot and main.
Hi there
Have you got any photos of the water rooting for dual cooling?
Thanks John
King Kang
Cary, NC
Here's one way to do it.
index.php
