Chunk of coupler dampner missing, time to replace?
Just picked up an 03 SJ on Friday. Seemed to run good other than a couple self induced problems. After riding it for the weekend I noticed some rubber on the underside of the hood. Upon closer inspection I notice that there is a bit of rubber missing from the coupler dampner. Should I go ahead and replace it, or am I good to just keep an eye on it and keep riding? It's a cold fusion coupler with the red dampner.
Not sure how old the rubber is, or if it was like this when I got it, but seems like this is an indication that motor may not be lined up properly.
iangdesign
Cats, lots of cats!
United States
I'd pull the rideplate and check the tightness of all your pump bolts and check the motor mounts and bolts. There is an underlying problemo for sure.
McDog
Other Administrator
Staff member
South Florida
Not necessarily. My tpe1105 eats cold fusion dampeners in a short time but does fine with a rubber kawi dampener. I have heard that it is a common problem with big motors....that means it's possible with smaller motors with enough use.
eastcoastjumper
James
Long Island
I ate 2 of those red cold fusion coupler dampners last year in my 701 surf ski. Switched to the Kawi Ada couplers and ate up 2 of those already this season. It's from the motor moving around too much, broken mounts, hitting bottom, or incorrect alignment. The small fingers of those couplers don't help. At least they are stronger than the stock cast set
BruceSki
Formerly Motoman25
Long Island
It's from Kawi couplers. They are junk. Aftermarket or stock. If you actually ride your ski they will break.
Try 5 finger Yamaha couplers.
The motor is a 760 bored to 781, and I think the dampner is ~3 years old, so it may be just something I have to keep an eye on. I was practicing barrel rolls all weekend as well, and had lots of upside down and side landings, so that probably has something to do with it too.
To replace it, can I just unbolt the motor, slide it forward, replace the dampner and bolt everything back up? This assumes everything is properly aligned.
