I had a 6m6 in this thing till saturday my ski started acting up, it wouldn't pull rpm quick, felt like half throttle when it was really full throttle and would have trouble plaining out, changed plugs, checked over heat sensor and then put onto the trailer and took the motor out after doing a compression check 123/125
so now i have a fresh bore 61x .040 over i cleaned up the ports on the jugs (port matched) didnt take any extra out. i need advise on where i should start with specs on the carb
ski setup
61x jugs, case, intake
boysen reeds
open element f/a
6m6 exhaust (runners opened up) until i can get a better pipe
13/17 concord with stubby cone
carb is off 6m6
120 pilot
135 main
low screw 2 turns out
high screw 3 turns out
i dont know the pop off pressure yet assume stock
i took it out yesterday to try to tune it just was acting weird, did a 5 sec full throttle pull and shut it down to check spark plugs and it seemed lean i dont want to burn it up
now the cdi is a 61x, i have about 6 rides on it, I've had them go bad before but not run half ass -is this possible?
any help would be great
i live in michigan and im under 1000ft altitude
thanks in advance keith
ski setup
boysen reeds
open element f/a
carb is off 6m6
120 pilot
135 main
