Carnage inside flywheel cover
tor*p*do
Squarenose FTW
NW NC
Ski quit- no spark, pulled cover, stator was chewed up!
Finally got flywheel off
to reveal mostly awol crank seal :eek:mfg:
stator
tor*p*do
Squarenose FTW
NW NC
pull flywheel, bendix looks good (dang, spent $200 on a new one)
crank bearings look good, crank tight, smooth . . .
wait a minute, you arent supposed to see bearings?
tor*p*do
Squarenose FTW
NW NC
so do I:
a. Pound in a new seal, jbweld, superglue, etc. Run her til she blow again . . .
b. Drop lower case and just replace seal.
c: Pull apart motor, bore once over, rebuilt crank, throw good money after bad . . . . .
It had 125 psi ea. before she quit running, but that may have been from the leaking crank seal?
