- California
Looking to sell my build that I started but can’t find time to finish.
$15,000 Open To Offers
Located in Southern California
Hull & Components
2018 Carbon California Phantom hull - Used
RRP Billet handle pole - Never Used
RRP 0 degree fat bars - Never Used
Thrust Innovations EZ-Flow Pro Trim -Never Used
Skat-Trak E-75 Magnum 155mm Prop 8/16 - Never Used
Oem 155mm Pump Housing - Used
Power factor Exhaust Kit - Never Used
NO ELECTRONICS
NO CARBS
ENGINE
Dasa 1000 10mm stroke X 89.5mm bore, set up to run on 91-93 octane (44cc domes).
comes with a Dasa intake & speed plate and V-Force 2 reeds.
Bought the engine used, replaced every gasket, crank seals, pistons, spark plugs, hose fittings pretty much a complete makeover. Only thing not replaced was crank bearing as they are in great shape. The cylinder has the 4 extra cylinder cooling lines option; they could be plugged if you don't want to use them.
Don’t have time anymore to finish this build, everything is super clean and most parts are brand new!
Might be missing a few miscellaneous parts so if interested message me and we can talk.
Hull & Components
NO ELECTRONICS
NO CARBS
ENGINE
