- marysville,wa
I have an 02 superjet w/sizzler pipe , started with b pipe jetting settings- here's what i got. Got low end dialed good, mid seemed ok , tested top end and plug was white-lean. Went 3 turns out-max and still only a little color. Going go from 135 to 140 main on dual 38's to richen top end. This will also richen up midrange right? Should I go more than 140 because it was so lean? Also will this alter the bottom which is good right now?
