Dual 44s typically had pumps on each carb. If you don't want to add the second pulse fitting you could purchase block off plates and add an external high volume mikuni fuel pump. Has dual outlets. You will have to make a bracket to position it properly. I have run both dual pumps and the single high volume external pump.on large carbs and they both work well.
If you wanted to keep 38s, a lot of riders recommend removing the chokes for added airflow. Could also have them taper bored.
