typicaly you would take the carb off to check andthing with it. I would say rebuild it. the rebuild kit is about $25 or $35. very simple and comes with instructions. other than that take out your high and low adjuster screws and check the ends of them for condition and wearing, check the o-ring on the end of each, spray some carb (I like throttle body) cleaner in each. there is also a really small filter in there that get clogged even with a little hair or something that wont allow enough fuel by for open throttle. Rebuild kit will come with a new one.
Also right next to the needle there is a little block you can take off that will give access to you main jets, spray cleaner through thoughs.
Other things to try would be to run a fuel line straight from your tank to your carb to bypass your fuel selector switch (those go bad/get clogged). Make sure your intake gaskets are good and that you have a good pulse in the hose that goes from your intake to you carb next to where the fuel lines hook up.
