Super Jet Can I use the ADA exhaust bracket on a Pro-Tec C2 head?
rxp489
CC Racer
Mineral, VA
Anyone know if the ADA exhaust bracket will work on a Pro-Tec C2 head? Tried searching for info on this, but didn't have much luck. Basically a friend of mine hooked me up with this head cheap, but doesn't have either of the exhaust brackets. I contacted Pro-Tec, but they only sell the 3 hole bracket which is for the stock pipe and is too far back to mount on my type 4 pipe. Figured the 2 hole bracket would be hard to find since they no longer sell them which my next solution would be to use the ADA bracket if it'll work. Also looking for the bracket that mounts to the flywheel cover if anyone has one.
Thanks,
Scott
