can i put a stater out of a 650 sj into a 701?
njfl
X-H2
Can't tell from your first post, but just to be clear, the 650 (6m6) and 701 (61X only) share the same stator and flywheel. 701 (62T) has a different stator and flywheel.
You can use the 650 stator in the 62T 701 also, but you have to use the 650/61X flywheel with it.
WAB
salty nuts
coastal GA
Oops, I thought it was starter also. Sorry.
You can use the stator for a 650, but you have to have the right flywheel to go with it like NJFL posted. (61x or 650 flywheel)
