bulkhead removal
SuperJETT
none
Assuming you have the top deck off, start with the sides using hammer/prybar/screwdrivers/whatever to break the hull loose from it. Once both sides are broken loose, you can do the same and beat it forward to break it loose from the bottom/driveshaft tube.
That's how I took the bulkhead out of my squarenose conversion in one piece.
sj, cali
i tried to heat a piece of the green matter and all it does is get support hot doesnt melt??
cause it has alot of unneeded holes and it looks like :):):):) so im going to out another one in!
SuperJETT
none
If the hull is still assembled, I doubt you'll get it out unless you chop it into pieces.
