norcal ex said:
i already have some of this stuff :
[X] cleaned stock 701 cylinder (wet jet 701 with a fresh rebuild)
[ ] 62T cases
[ ]lightened flywheel (im getting an advent so i need stock flywheel)
[ ]carbontech reeds (these dont help with performance do they? they just make it so if they break they wont destroy the engine like the stock ones will..correct?)
[X]180psi comp
[X}b pipe
[ ]twin 38s
[X]impros 13/16 cutback prop
[ ]bored nozzle
[X]stubby pump cone
will 62T cases, twin 38's and a bored nozzle really be what i want. i can tell my skill is being restricted by the engine. will they unleash the beast? i wanted to build another engine so i will have a spare to work with for a future project or if it explodes... hmmm
Hmm, from what you've listed there, you could probably build my old motor (the one that is in SJ13's boat now).
You would need:
Hot Rods Crank - $450 ish
Milled stock head - $100 to mill, do you have a stock head?
Sport Port Template - $75 (3-5 hours to port it with a dremel)
Pro-X pistons (or OEM) top-end kit - $250
Carbon tech reeds - $60 (I think)
RIVA reed spacer - $60
Stock 38's with a stock flame arrestor and manifold - $200
Lightened stock flywheel - $??
The rest of the stuff is free little things that add up.
Rough up everything on the intake up to the combustion chamber. Match all gasketed surfaces. Lightly port your cases (smooth sharp corners). Polish your exhaust manifold - Bore it out if possible.
I think you're gonna be able to make a pretty decent motor.
