- Raleigh NC\Lake Jordan
im done, just waiting on my start stop switch... I swore i didnt sell mine from my last engine. Dont you hate it when your waiting for 1 single part thats holding you up??
Brock...I know it's a PITA but adding the extra length on ur SS is a good thing. I do it to all mine so that I can disconnect the whole assembly on either end. I usually put a break inside the hull after it exits the pole wire guides. I use the heat shrink bullets from mcmaster and then I can disconnect and pull the whole SS assembly off the pole. I use some of that mesh wire loom to bundle all the wires together and then slides easily back down the pole. If ur SS is not working from the start I'd send the pos back and bitch to them bout it. I can't stand misrepresented parts.
its a 701, i know the 62t isnt the best cyl for bottom end, but thats not the case here.
38mm dual carbs, I just took them both apart, and found that one carb had a 130 main, and the other a 120 main(wtf?). cant see the markings on the pilot jets, and same case for the needle\seat.
I dont know what to run either, searched for hours trying to find some hints on a 62t\62t b pipe setup. Theres no yamaha or jetski shops around so I will have to order all jets\parts online.
got it running right, everything is almost closed, does that mean my jets are too big? Im at about 1\2 on the lows, and 1\4th on the highs. I got a good 5 hours of riding today, it was a blast, nothing really slowed me down. I did however break my exhaust hanger thing i epoxied to the hull, so now my exhaust tube is rubbing on my battery plate. Im probably just going to throw some turf on it and call it good till the winter. I also lost a steering bolt on my nozzle, but had a spare.
