What can I use to fill the vent holes on my sqaure hood? I epoxied some lightweight marine plywood in (from the bottom), and on one side, I used some leftover peanut butter to give it a start, but dont want to use expensive epoxy to fill it all the way (its about an 3/16 of a gap). What will bond to the epoxy peanut butter (I used wood flour) that I've already put in there, and the wood, and the hood material with of course not adding too much weight?
I have some of the evercoat for marine, but was worried since it was polyester based that it wouldnt bond all the way.
(BTW, Idok if you read this, the liquid nails was a real b**** to remove! Had to grind it out with some 10 grit floor sanding discs)
