Only a few weeks til the Dells Freeride, and I would really appreciate some help with this one...
I have a 701 RN Superjet with a B Pipe, stock waterbox, and dual cooling with a FCV. The cooling is routed pretty much identical to the picture below; with the only difference being that I used a Y fitting to connect the engine outlets back into one pisser. The pisser from the engine is 6.5mm and the exhaust pisser is 8mm.
I ran it all last year like this with little to no issue. This year I took it out and it seemed to run great for 15 minutes or so, but then all the sudden it bogged really bad and it wouldn't pull out of. I ran it to shore (not that far, but bogging the entire way) popped the hood off and could hear what sounded like the crackling noise of something being really hot. Splashed water on the expansion chamber and it didn't even sizzle, but then I realized it was the waterbox which had gotten hot enough to melt some hydroturf and a little bit of my steering cable. Water beyond sizzled off that thing, it was HOT! I know water was coming out both pissers while I was riding so I have to imagine the stinger was getting water. Any ideas to what the problem could be?
*Full disclosure: I did make the following mods to the ski over the winter:
- Blasted and ceramic coated all of the exhaust components
- Replaced the two lower screws on my B Pipe with oversized screws. I don't know what they were set at before because they were siezed, but they are both closed now and the top screw is opened enough to spray a decent mist when hooked to a garden hose.
- I found that the timing was approximately 1-2 degrees retarded before, so this year I adjusted it to be 1-2 degrees advanced.
- Replaced a bunch of old wiring with new stuff. I fought poor connections all last year.
