Blueprinted Pump
2lick
Brap!!!
Limerick, PA
if you have the time... its gonna help.....
i wouldn't put down time during ridding season to do it thought... its more something to do over the winter when your bored....
aqua
the taco
i did mine a couple of weeks ago......question is this. should it be a nice smooth surface like polished or should it be rough like 60 grit paper would make it. would smooth be so bad....after all polished exhaust ports are good. i have heard both sides....some say smooth, some say rough. i have heard that a hull is more efficient at lower speeds if it is rough but would that apply to the high speed flow through the stator. from what i have heard....faster speed water flow is less affected by the surface that it is flowing over. what is everyone elses take on this?
meatball
User Title Unavailable
Maryland
shouldnt make a huge difference I dont think. The idea is the smoothest flow of water possible with the least turbulence, 60 grit finish is so much less an obstacle then the giant, sharp, casting marks that are 90 degree angles and such, also causing each vein to vary in size. I wouldnt worry about smoothing it or roughing it, just dremel the castings and leave it. The turbulence cause by the valleys created by 60 grit paper would be negligible. The only reason I could see for that is to make lateral sandings the way the water flows to help 'tracking' but thats unnecessary.
I don't think so. IMO
Mark44
I agree with mark I didn't change a thing on my ski the wonter I blueprinted my pump and I couldn't tell a bit of difference. I agree thatmy own labor is cheap..... Hell my labor is cheap anywhere you should see my pay check. But anyhow if you have to do something bore your exhaust manifold out a mm or 2 and polish that up.
just joe
NorCal
Here's mine, since the ski is a complete build I won't really know if it makes a difference. Sandpaper rolls, beer, and time...
aqua
the taco
i thought about sharpening the trailing edges of my stators also but when i put the reduction nozzle on i could see where the stators meet up with the ones in the reduction nozzle so i didnt. but what i did do was sharpen the trailing edges on my intake grate and filled in that hollowed out area at the rear of the grate with jb weld. :smile:
meatball
Maryland
Ideally, most of the stuff should be shaped like long tear drops (the fabled ones everyone thinks of, not the realistic hamburger patty ones), with the 'fat and round' edge of the tear facing where water comes in, and the
sharp' edge of the tear facing the water's exit. However, the difference in the veins that would make would be minute and infintesimal IMO.
G
Goose
Guest
just doin some thinking out loud but anyone ever think of taking some kind of epoxy and spreading it in between the vaines around were the driveshaft bearing is then smooth it out wouldnt that kinda make the same effect as the tbm pump cone if you understand where imtalking about and would it hold?
meatball
Maryland
seems like it would be a lot of work to get it smooth, and more importantly so the volume of each section is the same so water flow is the same.
