Blowsion Side Rail Extensions
N3vrSat1sfied
Military Member
Fort Worth, TX
Anyone use the Blowsion Side Rail Extension?
I had them on and took them off or they broke off rather. I tried everything. Weldwood the extension to the hull and I used 5200 on top and bottom of it. I then glued the turf to the hull and extensions. Then ran Screws with finishing washer all the way thru from the turf to the bond line about every 12" and then things still broke off in the surf (you can see the screws in my avatar). I called blowsion and they said to rivit them instead. I dont see how that would help it the screws and nuts dont work. Anyway I ripped them off and am not going to put them back on. I turfed over the stock purple bumpers and i am quite happy with that.
I just wanted to post up my troubles and see if anyone else has had these problems.
