Super Jet Blowsion dual breather bracket with stock pole
Crab
thanks darin...noswad!
Seattle
You might need to carve out some of the foam in the pole. I use a dual XM bracket with a stock pole and one hole plugged up.
Finland
i removed some foam from the pole but it was still a huge pain to get the hoses through and the bolt in place..
i run my pole tight and it will not go over front because the hoses are limiting it's movement, easiest would be to cut the pole bottom piece a little so it would let the hoses install correctly
