Blown Crank Bearing.. Pics Added!! :(
djkorn1
kidkornfilms
Cleveland Ohio
They are actually behind the flywheel by the crank seal. It is definately that front bearing... I knew I should've put a new crank in. Micmac warned me.:banghead:
djkorn1
kidkornfilms
Cleveland Ohio
Ripped it down: Front bearing is toast and the front seal has a small hole in it. The rest of the crank is perfect. Micmac is taking it in to work to do some measurements, but it seems absolutely perfect. (I might just need to change the one bearing, if I am really lucky). We allready pulled it off. The cases are perfect. The cyllinders might need a hone and might need a bore. He is measuring those tomorrow too. The one piston is perfect and the other has some small little chunks out of the top where the bearing parts snuck past the ring, so I am putting a whole new top end in, regardless.
All I can do now is wait till tomorrow. :dunno:
YAMA CAT
Catnip Junkie!
B'ham, AL
I feel your pain. I had the same thing happen to me on my squarenose. Maybe you will get lucky with just a hone on the cylinder. Good Luck!
djkorn1
kidkornfilms
Cleveland Ohio
Didn't even look at my ski today. If I did, I might barf. I will be back on track tomorrow. Sorry bout the pics. I forgot the camera at my bros.
djkorn1
kidkornfilms
Cleveland Ohio
pics. .:frown:
