- sunbury ,ohio
Im currently running a 83.5mm bore ,riva red pipe ,dual 44,ported ,welded crank ,210 psi comp. ,105 octane gas , it currently has the 14-22 skat prop.... My problem is i sucked a piece of wood and it chipped up the stator severly so im replacing it ''had one on the shelf '' what luck ! , Impeller run-out measures fine but it has cavitation burns on the leading face and outside edges ,what causes that ?, I also have a 15-20 ybsc-c solas prop on the shelf , would this be a good replacement ? i dont do many high speed runs but this ski is an arm stretcher on the bottom and fast on the top the way it is ! how will the 15-20 compare on bottom and top ? any help or opinions appreciated while i got the pump out for 2 days:boggled:
