bilge ?
if you looking at the back of my ski on a 94 superjet.... is the factory bilge the left or right hand side?.. there a big rubber hose that is on the left hand side that bolts to the ride plate on the right the hose goes into the pump.... both go into the pump... which one is my stock bilge which is my water for my exhuast?????
Shifty
- SuperJet Thursday -
Looking at the rear of your ski... on the right is your cooling line. This goes right through your hull and exits on the engine compartment.
The large rubber "exhaust pipe" looking thing on the left of your pump is the syphon bilge contraption. There is a bilge line behind that. The newer RN use a different system.
Its on the the Port side
R
ridethelip
Guest
The cooling line is on the steering cable / exhaust side. The opposite side is the bilge line.The large hose coming off the vein section is your bilge which then bolts to your ride plate and The small hose for bilge attaches to that.They ditched that set up and went to the reduction nozzle on later years. 94??
