is a new oem x2 seal molded for the x2's contours? or is it just a bendable roll? it would seem that if it can be shaped/reshaped, you could put the seam elsewhere. :dunno: i guess i hafta look at one
I thought of that, it might need a week to really dry out.a good way to hold it on would be contact cement. youd have to apply a lot and install the seal while the contact cement is still wet and thick.
Tried that, it lasted about 2 hours in the ocean, probably too much hull flex jumping.when i put my hood seal on i just used a rubber malet on it all around, never used any adhesive, and its been on just fine all summer, never had a problem with leaks either.
